speed data
  hi there
how can i read the speed of the different axis of the robot during a movement ?
for example moving axis 1,30 degrees,with 1000 mm/s , i want to draw velocity / time curve during this movement  ,how can i reach the data for this?
  • I would try to use MoveAbsJ
    used to create moves by axis angle
    example from manual
    MoveAbsJ *, v1000T:=5, fine, grip3;
    The robot with the tool
    grip3, is moved along a non-linear path to a stop point which is
    stored as an absolute axis position in the instruction (marked with an *). The entire movement
    takes
    5 seconds.
