About the BootLoader
Nick
Now I upgrade my IRC5 with robotware 5.06 from 5.05,but now I can't run the X-Start ,Once run it the robot controller will restart and display "connect to the controller " then restart and repeated.
I Power of the robot ,take down the Harddisk ,open it directly by the PC,I find the "system.dir" disappeared,I rebuild a restore "system.dir" the controller can work,but I can't run the X-Start.
My BootLoad version is 1.13
1
Why don't you make C-Start instead?
then, Download 5.06.
and You also need to upgrade BootLoader as well.
The latest version is 1.14e
