Unhandled Exeption in eventmanager
I had severel viewpoint that i use in evenmanager to change view during videocapture under simulation. My viewpoints are now deleted but nut my events. when i open eventmanager and try to delete events with the deleted viewpoints i get this exeption when i try to delete them. After clicking no to use RS anyway i get the exeption again and the event is deleted.
RobotStudio .NET exception: Unknown Error: ArgumentNullException
Base exception: ArgumentNullException
Value cannot be null.
Parameter name: value
   at System.Windows.Forms.ListBox.ObjectCollection.IndexOf(Object value)
   at System.Windows.Forms.ListBox.ObjectCollection.Contains(Object value)
   at EventManager.CameraControl.set_Action(EventTableAction value)
   at EventManager.SingleActionEditor.set_Action(EventTableAction value)
   at EventManager.MultipleActionStatusEditor.listViewAddedActions_SelectedIndexChanged(Object sender, EventArgs e)
   at System.Windows.Forms.ListView.OnSelectedIndexChanged(EventArgs e)
   at System.Windows.Forms.ListView.WmReflectNotify(Message& m)
   at System.Windows.Forms.ListView.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Just an info to RD Wink
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
  • Thank you for bringing this to our attention. We will investigate it and try to fix it.
    ABB
  • Thumbs Up
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
