Unhandled Exeption in eventmanager
                    Klaus
                    I had severel viewpoint that i use in evenmanager to change view during videocapture under simulation. My viewpoints are now deleted but nut my events. when i open eventmanager and try to delete events with the deleted viewpoints i get this exeption when i try to delete them. After clicking no to use RS anyway i get the exeption again and the event is deleted.
                RobotStudio .NET exception: Unknown Error: ArgumentNullException
Base exception: ArgumentNullException
Value cannot be null.
Parameter name: value
at System.Windows.Forms.ListBox.ObjectCollection.IndexOf(Object value)
at System.Windows.Forms.ListBox.ObjectCollection.Contains(Object value)
at EventManager.CameraControl.set_Action(EventTableAction value)
at EventManager.SingleActionEditor.set_Action(EventTableAction value)
at EventManager.MultipleActionStatusEditor.listViewAddedActions_SelectedIndexChanged(Object sender, EventArgs e)
at System.Windows.Forms.ListView.OnSelectedIndexChanged(EventArgs e)
at System.Windows.Forms.ListView.WmReflectNotify(Message& m)
at System.Windows.Forms.ListView.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Just an info to RD
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
            Thank you for bringing this to our attention. We will investigate it and try to fix it.Henrik Berlin
 ABB0
             Best Regards Best Regards
 Klaus Soenderhegn
 www.cadalysator.dk0
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 31 AppStudio
