robtarget:=robtarget+10
I've got a list/path that includes hundreds of points. I'd like to run through a certain drill/deburring operation at every point. Rather than creating a program where I move to every point and call the same routine after every point (resulting in a zillion page redundant program), is there any way I can increment a variable robtarget? These points are not spaced or oriented in any consistent pattern so I can't just increment their components with trans or pose.
I've tried incrementing a variable num and writing that as an addendum to a string "Target_", but passing the new string to a variable robtarget fails since the string doesn't count as a reference/pointer or contain the right data type. What's weird is that Programmaker tells me there are no errors in my program. But RobotStudios dies/can't load the program as is. The relevant part in my short experimental program looks something like this (with everything defined appropriately):
WHILE point<50 DO
Apoint
:=ValToStr(point);
newstring:=Atarget+Apoint;
ok:=StrToVal(newstring,Target_point);
MoveL Target_point,v200,z1,tool0WObj:=wobj0;
rDRILL;
point:=point+10;
ENDWHILE
Lisa Cardon
Saving the world from the scum of the universe.
  • And yes, I'm trying to do this WITHOUT having to resort to an array. But if that's the only way to do it, could I please have the proper format/syntax for a robtarget array?
    Lisa Cardon
  • point starts as 10
    Atarget:="Target_"
    Lisa Cardon
  • *continues browsing the manuals* If there were something like CallByVar that worked for variables (persistant veriables?) instead of procedures only... then I think I'd be set!
    Target_point
    :=(CallByVar("Target_",point));
    rDRILL;
    point
    :=point+10;
    I really wish this worked....
    Lisa Cardon
  • Hi
    What you could do is create your own Move instruction which includes the stuff you want to do after the motion. Here is just a simple example how to do it, have also included the array stuff.
      VERSION:1
      LANGUAGE:ENGLISH
    MODULE ABB
      VAR robtarget myTarget{2}:=[[[0,0,0],[1,0,0,0],[0,0,0,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]],[[0,0,0],[1,0,0,0],[0,0,0,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]]];
      VAR robtarget myTarget1:=[[0,0,0],[1,0,0,0],[0,0,0,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
      VAR robtarget myTarget2:=[[0,0,0],[1,0,0,0],[0,0,0,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
      VAR robtarget myTarget3:=[[0,0,0],[1,0,0,0],[0,0,0,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
      !My special instruction
      PROC MyMoveL(
        robtarget mytarget,
        speeddata myspeed,
        zonedata myzone,
        PERS tooldata mytool,
        PERS wobjdata mywobj)
        MoveL mytarget,myspeed,myzone,mytoolWObj:=mywobj;
        !do the drill stuff
        rDrill;
      PROC main()
        !IF you want to loop thru the array of robtargets
        FOR i FROM 1 TO 2 DO
          MyMoveL myTarget{i},v200,z1,tool0,wobj0;
        ENDFOR
        !or just if you want to have the motion instruction in a flow
        MyMoveL myTarget1,v200,z1,tool0,wobj0;
        MyMoveL myTarget2,v200,z1,tool0,wobj0;
        MyMoveL myTarget3,v200,z1,tool0,wobj0;
    ENDMODULE
    Per Svensson
    Company Specialist
    ABB Automation Technology Products
  • But the question is, can you construct the robtarget name using a variable?  For example, can you pass the robtarget name of "Rob_Move"+NumToStr(x,0) as a parameter to the subroutine as the name of the robtarget?  I'm guessing that since the name, in this example, is constructed as a string that it will pass it as a string to the subroutine.  If that is the case, you will get a type mismatch error.
    Only the array portion of the suggested solution uses a variable to define which robtarget will be used.  Can this be accomplished on non-arrayed robtargets that have similar names except for an identifier, such as Rob_Move1, RobMove2, RobMove3.......RobMove20.  ??????
  • have done this before (years ago and cant remeber exactly the process)
    I think I used GetDataVal
    something like this;
    GetDataVal "target"+ ValToStr(num), temprobtarget
    MoveL temprobtarget
    also answered the over in this post too;
