Not a paint system [Painting PowerPac]
            Hello,This issue is reported & shall be resolved.As a workaround you can load the PaintL & SetBrush instruction templates from the Painting PowerPac installed folder (usually under C:Program FilesABB Industrial ITRobotics ITPainting PowerPac 5.13)Once the templates are part of the RS station, you can use them to create path.Subsequent messages when activating powerpac for the same station can be ignored.//Sudarshan0
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 30 AppStudio
