device configuration import and export [WebWare SDK]
Hello.
Little question.
We setup a Profile configuration on a PC using device configuration utility. Is it possible to export and import on another PC the same configuration (variable subscription, tags names) without rewrite all by hand?
Thank you in advance for your help.
Davide
Davide
Hi Davide
The configuration settings is stored in
C:Documents and SettingsAll UsersApplication DataABB AutomationInterLinkPer Svensson
Company Specialist
ABB Automation Technology Products0
