DSQC 652 how much current?
Anybody know how much current I can pull from the output chanels of the DSQC 652 (Digital IO), I can not find any documentation about this.
Hi,The DeviceNet application manual has this information in the chapter on the boards and units.It states the following for digital outputs:Rated voltage = 24 VDCVoltage drop over output maximum 0.5V with 500mARated output current 500 mA/channelCurrent lmit typical 1.4ALeakage current maximum 0.1 mADelay output 0.5 msHope this helps.RegardsGraeme0
Tnx, great info, but where did you find it? I'we been reading the DeviceNet app. manual that i have available, this one: 3HAC020676-001 Revision: D, but I can't se aything about it there.. :P
Hi,I got the information from rev K of that manual.RegardsGraeme0
Tnx.
- 365 IRC5
- 84 OmniCore
