Reg the RobotStudio will in Windows 7 OS
Edwin
I have doubt regarding the Robot Studio will work on the Windows 7 operating system. Because we are upgrading the OS, so i would like know the Windows 7 support the Robot studio.
Thanks and Regards
Edwin
Windows 7 is not supported by RS 4. You can always give it a try, but if it doesn't work you will have to stick to one of the supported Operating Systems, check the Release Notes.Henrik Berlin
Hi, Robotstudio 4 does work on Windows 7 Ultimate using Windows Firewall and Microsoft security essentials. It has to be installed in windows xp compatability mode (you keep picking install RobotStudio and eventually it offers you the choice). Once installed its main issue is with the virtual controller and your firewall. You must right click the quickteach icon on your desktop and select properties and then the Tab Windows compatibility, then check the box that says run as Administrator. The first time you run quickteach it comes up with firewall messages that you have to allow it to work. There should be three that need to be allowed. Once started close down and then you can uncheck run as administrator. Load you licenses and it works.RegardsRichard Ramos1
- 367 IRC5
- 858 RAPID Programming
