External axis setup
Hi friends
   i am trying to setup an external axis (track) in X-Y direction for 6600 robot in robotstudio .
  i dont have a readily available track for this in library
 so i had used create mechanism option in robotstudio to create external axis, and made  X-Y track.
  now i am not able to build a system with this external axis(gives unknown error )
  can someone help me how to create a system for X-Y motion external axis and robot
  Thank u
   Raj
Raj
  • You need to contact ABB and request an Additional Option Mediapool that supports your 2D track.
    ABB
  • Thank u Mr Henrik for ur reply
      i will try to contact ABB for the additional mediapool .
      meanwhile is there any chance of getting the backup of the robots with X-Y or X-Y-Z track motion .
      if someone using the robot with track motion kindly send me the backup of the robot.
      Thank u
       Raj
    Raj
  • Hello Raj!
    My name is Classe Filander and I work in the RobotStudio development team. Rigt now I am actually working on a configuration tool in RobotStudio to set up external axes. The tool is not ready to be used yet, but if you send me your station I will generate a configuration file for you.
    Best Regards
    Classe Filander
  • hello Classe
        thank you for the support,
      i can send u the pack and go of my cell with the mechanism.
     can u give me your mail id so that i can send it to your mail.
      Best regards
      Raj
    Raj
