External axis setup
Hi friends
i am trying to setup an external axis (track) in X-Y direction for 6600 robot in robotstudio .
i dont have a readily available track for this in library
so i had used create mechanism option in robotstudio to create external axis, and made X-Y track.
now i am not able to build a system with this external axis(gives unknown error )
can someone help me how to create a system for X-Y motion external axis and robot
Thank u
Raj
Raj
You need to contact ABB and request an Additional Option Mediapool that supports your 2D track.Henrik Berlin
Thank u Mr Henrik for ur replyi will try to contact ABB for the additional mediapool .meanwhile is there any chance of getting the backup of the robots with X-Y or X-Y-Z track motion .if someone using the robot with track motion kindly send me the backup of the robot.Thank uRajRaj0
Hello Raj!My name is Classe Filander and I work in the RobotStudio development team. Rigt now I am actually working on a configuration tool in RobotStudio to set up external axes. The tool is not ready to be used yet, but if you send me your station I will generate a configuration file for you.Best RegardsClasse Filander0
hello Classe
thank you for the support,
i can send u the pack and go of my cell with the mechanism.
can u give me your mail id so that i can send it to your mail.
Best regards
Raj
Raj0
- 346 IRC5
- 73 OmniCore
- 844 RAPID Programming
- 20 AppStudio
- 108 Collaborative Robots
