Calling PowerPac Functions using RobotStudio SDK?
shurd
Does anyone know if it is possible to call PowerPac functions using the RobotStudio SDK? I am wanting to set up a custom AddIn for RobotStudio that calls particular functions from the Machining PowerPac (e.g. the Solution Wizard), so that I can automate parts of the path generation process for a end user. I could use an external macro to do this, but would love to be able to wrap it all up in C# and the AddIn if I could. I have added the MachiningPP dll as a reference to my AddIn project and can see a bunch of classes etc. inside this dll, but without any documentation I'm a little bit blind.
Hi shrud,in general the PowerPacs does not have an API. For Painting PowerPac we are working on an API to access the path generation functions. This is not yet released.0
