RS 5.13.03 download fails to start
Kevin
I have been trying for two days to download, eventually getting timeouts with nothing downloaded. I can download a PowerPac from the same page OK.
Does anyone else have the same problem?
Thanks,
Kevin
Thanks,
Kevin
Hi Kevin,I was able to successfully download RS 5.13.03 just recently. However, if you are running RS 5.13.02, there is no need to upgrade. The only difference is an installation issue with PC SDK / FP SDK that is resolved with 5.13.03. Unless you experience that problem, you can just as well wait until RobotStudio 5.14 is released. It will be available for download in a couple of weeks.Henrik Berlin
ABB0
- 304 PowerPacs
- 354 IRC5
- 850 RAPID Programming
- 26 AppStudio
