ERROR IN screen maker
h.esk60
in ScreenMaker
hi
When i want to deploy project in screen maker and download screen in controller this error appear. Please see attach file
Many thanks and best regard.
webwiz/3908/11.JPG webwiz/3908/22.JPG
Moved to ScreenMaker forum.Henrik Berlin
hi
Please help me about this topic.
many thanks
Hello,I would like to know the scenario related to this error, hence i am posting some questions:This could be a good start , i think.1. Are you trying to deploy to a virtual controller/Real controller.2. If virtual is the virtual system in to which you are deploying the application present on a network drive.3. If real have you tried on other controllers too.4. Do you have administrator privilege on the machine where RobotStudio ScreenMaker is installed.Thanks0
Hello,Many thanks for your favor.1. Are you trying to deploy to a virtual controller/Real
controller:real controller2. If virtual is the virtual system in to which you are deploying
the application present on a network drive.3. If real have you tried on other controllers too.: i have only one irc54. Do you have administrator privilege on the machine where
Robot Studio Screen Maker is installed.:you mean i
should administrator privilege on the robot?where is this setting
in pendant ?Many thanks and best regard.0 -
have you upgraded your flexpendant firmware ??
and also have you got the "screenmaker" software option active in your IRC5 ??
Do not fear to be eccentric in opinion, for every opinion now accepted was once eccentric..0 -
have you upgraded your flexpendant firmware : no i don't upgrade firmware how can upgrade it?
and also have you
got the "screenmaker" software option active in your IRC5 ??yes i have this option
create a system using the new robotware and download to controller.. firmware will upgrade..
(be sure to take an image of the card before you do that, in case of any problem later)
- 350 IRC5
- 848 RAPID Programming
- 21 AppStudio
