CAD Converter - Selecting folder destination
Error select the destination folder for the name is repeated two times.
Erro selecionando a pasta de destino, fica repetido 2 vezes o nome.
webwiz/3047/CAD_Converter_1.JPG
after selection
ApA3s a seleA?A?o.
webwiz/3047/CAD_Converter_2.JPG
  • Hi,
    I can't repeat your problem.
    Have you tested with the RS 5.14 Cad Converter?
    ABB Robotics
  • It is clearer now ?
    EstA? mais claro agora ?
    Win Vista 32.
    webwiz/3047/CAD_Converter_3.JPG
    webwiz/3047/CAD_Converter_4.JPG
  • Unfortunately, I cannot reproduce the problem. Do you get the duplicate path problem for all paths and folders, or just some? Do you get the same problem when you select the folder in the view to the right?
    As a workaround, I suggest you create a subfolder that matches the one RobotStudio suggests, i.e. create a folder named Tools in your folder named Tools, but select the first Tools folder.
    Henrik Berlin2011-04-29 16:04:38
    ABB
  • This temporary solution has been used. But the error continues.
    Esta soluA?A?o temporA?ria jA? foi usada. Mas o erro continua.
