AB MicroLogix with IRC5
Anyone tried to communicate with a IRC5 Robot using a AB MicroLogix 1400 using Ethernet IP?
  • Hi,
    Are you using the FieldBus adapter or the Master/Slave connector?
    Is the Micro Logix 1400 similar to the RS Logix 5000?
    graemepaulin2011-04-30 11:27:03
  • Hi,
    I am almost sure that only the compact logix and control logix family are "real" ethenet IP controller. The ethernet port on the Micrologix 1400, SLC 500/5 for example, are only for programming or communication whit a HMI.
    Confirm whit your Rockwell distributor!
