ProcCall
Hello
I would like to create a path with the RS API and in that path add ProCalls to existing paths.. It seams that I cant make a action instruction description for ProCall in RS. If so I could only make RsActionInstruction, but I can understand why I wouldn't work do ProcCall is a rapid function but there half to be another way to make calls to other paths in a path also in RS?
