AB MicroLogix with IRC5
esbipa
Anyone tried to communicate with a IRC5 Robot using a AB MicroLogix 1400 using Ethernet IP?
Hi,Are you using the FieldBus adapter or the Master/Slave connector?Is the Micro Logix 1400 similar to the RS Logix 5000?graemepaulin2011-04-30 11:27:030
Hi,I am almost sure that only the compact logix and control logix family are "real" ethenet IP controller. The ethernet port on the Micrologix 1400, SLC 500/5 for example, are only for programming or communication whit a HMI.Confirm whit your Rockwell distributor!0
- 364 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
