How to read EN1 in Rapid program
I want to call a Trap routine when EN1 goes high. I tried this line:
ISignalDI EN1, 1, MyTrapProc;
The compiler complains that it does not know EN1.
In the CFG/IO list, EN1 has INTERNAL access, which is ReadOnly to RAPID programs.
What am I doing wrong?
Thanks for your help.
Gregory Ashmore
Xigent Automation Systems
1
Moved to RobotWare forumHenrik Berlin
Hello,Try creating a virtual output with ALL access and then cross connect the Safety input to the virtual output. Interrupt on your virtual output.BR Jim0
[QUOTE=j_proulx]Hello,Try creating a virtual output with ALL access and then cross connect the Safety input to the virtual output. Interrupt on your virtual output.BR Jim[/QUOTE]Thanks, Jim. The ABB guy has been here doing some training...and that is the solution he suggested.It works well.Gregory Ashmore
Xigent Automation Systems0 -
What if I want to change the value of signal EN1 during simulation? CUrrently I have no access right.
Hello,Because you do not have a real controller so EN1 does not exist. You will need to create a signal to simulate EN1.BR Jim Proulx0
In my case, I already create a controller. I can see En1 in the IO > Signal (offline tab), but i cannot access it since it is internal signal. Is there a way to change the value?
- 367 IRC5
- 858 RAPID Programming
