Sync don't work
I have a modul with 600 lines of code.
Now it won't sync to station.
I get no errors only these 2 lines.
Sync started and sync completed but nothing has been sync.
It worked an hour agoCry
Linje1_R2: Synchronization to Station started. 10-06-2011 15:36:18 General
Linje1_R2: Synchronization to Station completed. 10-06-2011 15:36:18 RAPID
Check program started: All tasks in system Linje1_R2. 10-06-2011 15:40:46 RAPID
Checked Linje1_R2. 0 syntax errors, 0 semantic errors.  10-06-2011 15:40:46 RAPID
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
  • Hi Klaus,
    If you send me a Pack & Go of the station I will test on my PC.
    ABB Robotics
  • Klaus
    Klaus ✭✭
    Hi Anders....P&G is 55 mb soo send it by www.sprend.com
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • Klaus
    Klaus ✭✭
    Hi Anders.
    I have seen some problems that desapers after making a P&G unpack it again.
    Just tried this on the P&G that i send to you without any succes.
    Just some Info
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
