SetGO in virtual FlexPendant
sturner
I can't get SetGO to see the group output in the virtal Flexpendant when programming this instruction
The group outp[ut works fine when tested in teh RS I/o simulator and pendants I/O window but does nopt appear to be seen when programming.
This noted in 5.14in both win XP and Win7
Can someone else confirm if they can program this, before I pull all my hair out !!!
It appears that if you create a group output by the name gOutput, It will work in the station I/O simulator and in FlexPendants I/O window but not in SetGO instruction.Not sure why? but now know not to us gOutput as the name of a group output.
sturner2011-06-17 23:26:220
