Auto Paint Stroke Problems [Painting PowerPac]
I get very strange paths when using Auto Paint Stroke.  I would attach a simple hood but it is too large and it will not zip small enough.  Here is a picture of the Auto Paint Stroke results.  image
Can anyone process this using AutoStroke and Explain what I may be doing wrong.  I have made my own simple boxes and they process well.  The problem seems to be with the more complex geometry.
  • Hello,
    It maybe the case that the CAD model of the Hood has several layers. Delete the duplicate layers and then identify Panel & try to use AutoPaintStroke again.
    Hope this helps
    sudarshan
