lamb button..?/o unit
Hi everyone...
I have ten lamb button with input output....
1. button X+    6.button is X-
2.button Y+     7.button Y-
3.button Z+       8. button Z-   and
4.button  50 mm
5.button 100mm
9.button 200mm
10. button is start button
? have to make a program with this buttons
when ? press 1.,4. and 10. button robot must move 50 mm X+
when ? press 7. 9. 10. robot must move 200 mm direction of Y-.......like offset...how can ? make this.....?
? need your helps ....thanksOuch
  • Marcel
    Marcel ✭✭
    Try this.
    Best regards
    Marcel
    MODULE Module1
     ! data
     ! Value
     VAR num nValueX;
     VAR num nValueY;
     VAR num nValueZ;
     ! Distance
     VAR num nDistance;
     ! actual position
     PERS robtarget pActual:=[[0,0,0],[1,0,0,0],[0,0,0,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
     ! tool
     PERS tooldata tEndEffector:=[TRUE,[[0,0,0],[1,0,0,0]],[30,[0,0,0],[1,0,0,0],10,10,10]];
     PROC main()
     ! main program flow
     ! initialisation
     SetDO doStart,0;
     SetDO doDist050,0;
     SetDO doDist100,0;
     SetDO doDist200,0;
     SetDO doPlusX,0;
     SetDO doMinusX,0;
     SetDO doPlusY,0;
     SetDO doMinusY,0;
     SetDO doPlusZ,0;
     SetDO doMinusZ,0;
     nValueX:=0;
     nValueY:=0;
     nValueZ:=0;
     nDistance:=0;
     ! wait for start
     WaitDI diStart,1;
     SetDO doStart,1;
     ! read actual position
     pActual:=CRobT(Tool:=tEndEffectorWObj:=wobj0);
     ! read buttons
     IF diButtonDist050=1 THEN
      SetDO doDist050,1;
      nDistance:=50;
     ELSEIF diButtonDist100=1 THEN
      SetDO doDist100,1;
      nDistance:=100;
     ELSEIF diButtonDist200=1 THEN
      SetDO doDist200,1;
      nDistance:=200;
     ENDIF
     IF diButtonPlusX=1 THEN
      SetDO doPlusX,1;
      nValueX:=nDistance;
     ELSEIF diButtonMinusX=1 THEN
      SetDO doMinusX,1;
      nValueX:=-nDistance;
     ELSEIF diButtonPlusY=1 THEN
      SetDO doPlusY,1;
      nValueY:=nDistance;
     ELSEIF diButtonMinusY=1 THEN
      SetDO doMinusY,1;
      nValueY:=-nDistance;
     ELSEIF diButtonPlusZ=1 THEN
      SetDO doPlusZ,1;
      nValueZ:=nDistance;
     ELSEIF diButtonMinusZ=1 THEN
      SetDO doMinusZ,1;
      nValueZ:=-nDistance;
     ENDIF
     ! move to position
     IF nValueX<>0 OR nValueY<>0 OR nValueZ<>0 THEN
      MoveL Offs(pActual,nValueX,nValueY,nValueZ),v300,fine,tEndEffector;
     ENDIF
     ! wait for releas of start button
     WaitDI diStart,0;
    ENDMODULE
  • I really appreciated for your helps....thanks so much Thumbs Up
  • I made this thanks for your helpsClap
    MODULE MainModule
         VAR num VALX:=0;
        VAR num VALY:=0;
        VAR num VALZ:=0;
      VAR num DIST:=0;
      VAR bool TEKHIZ:=FALSE;
      VAR bool TEKX:=FALSE;
      VAR bool TEKY:=FALSE;
      VAR bool TEKZ:=FALSE;
      CONST robtarget p10:=[[832.51,-0.02,1130.19],[0.258803,1.62466E-05,0.96593,-4.18923E-07],[-1,0,0,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
        PROC main()
      Init:
        WHILE TRUE DO
            LampChk;
      IF BUTONSTART=1 THEN
      MOVECHK;
      IF TEKHIZ AND (TEKX OR TEKY OR TEKZ ) OYNA;
      ENDIF
     ENDIF
     ENDWHILE
    PROC OYNA()
    VALX:=0;
    VALY:=0;
    VALZ:=0;
    IF (Buton50=1 AND Buton100=0 AND Buton200=0) DIST:=50;
    IF (Buton50=0 AND Buton100=1 AND Buton200=0) DIST:=100;
    IF (Buton50=0 AND Buton100=0 AND Buton200=1) DIST:=200;
    IF (ButonXP=1 AND ButonXM=0) VALX:=DIST;
    IF (ButonXP=0 AND ButonXM=1) VALX:=-DIST;
    IF (ButonYP=1 AND ButonYM=0) VALY:=DIST;
    IF (ButonYP=0 AND ButonYM=1) VALY:=-DIST;
    IF (ButonZP=1 AND ButonZM=0) VALZ:=DIST;
    IF (ButonZP=0 AND ButonZM=1) VALZ:=-DIST;
    p10:=CRobT();
    MoveL Offs(p10,VALX,VALY,VALZ),v100,z0,tool0;
    PROC MOVECHK()
    IF ((Buton50=1 AND Buton100=0 AND Buton200=0) OR (Buton50=0 AND Buton100=1 AND Buton200=0) OR (Buton50=0 AND Buton100=0 AND Buton200=1))
    THEN TEKHIZ:=TRUE;
    ELSE TEKHIZ:=FALSE;
    ENDIF
    IF (ButonXP=1 AND ButonXM=0) OR (ButonXP=0 AND ButonXM=1)
    THEN TEKX:=TRUE
    ELSE TEKX:=FALSE
    ENDIF
    IF (ButonYP=1 AND ButonYM=0) OR (ButonYP=0 AND ButonYM=1)
    THEN TEKY:=TRUE
    ELSE TEKY:=FALSE
    ENDIF
    IF (ButonZP=1 AND ButonZM=0) OR (ButonZP=0 AND ButonZM=1)
    THEN TEKZ:=TRUE
    ELSE TEKZ:=FALSE
    ENDIF
        PROC LampChk()
       IF ButonXP = 1 THEN
       Set LambaXP;
       ELSE
       Reset LambaXP;
       ENDIF
       IF ButonXM = 1 THEN
       Set LambaXM;
       ELSE
       Reset LambaXM;
       ENDIF
       IF ButonYP = 1 THEN
       Set LambaYP;
       ELSE
       Reset LambaYP;
       ENDIF
       IF ButonYM = 1 THEN
       Set LambaYM;
       ELSE
       Reset LambaYM;
       ENDIF
       IF ButonZP = 1 THEN
       Set LambaZP;
       ELSE
       Reset LambaZP;
       ENDIF
       IF ButonZM = 1 THEN
       Set LambaZM;
       ELSE
       Reset LambaZM;
       ENDIF
       IF Buton50 = 1 THEN
       Set Lamba50;
       ELSE
       Reset Lamba50;
       ENDIF
       IF Buton100 = 1 THEN
       Set Lamba100;
       ELSE
       Reset Lamba100;
       ENDIF
       IF Buton200 = 1 THEN
       Set Lamba200;
       ELSE
       Reset Lamba200;
       ENDIF
        PROC Init()
    ENDMODULE
