Robot Application Builder
Julito-
Hi I wish to know if it is possible to use robot application builder to develop application for S4C+ with pc sdk.
I appreciate your help.
Julien
Hi JulienUnfortunately it's not possible to use RAB for S4C+, it's only for IRC5. There was a bit similar product for S4C+ called WebWare SDK, which is based on ActiveX controls. However, I'm not sure about it's availability (and compatibility with latest Win versions) anymore and also it was a licensed software.S4C+ used RAP protocol (don't mix up with RAB - RobotApplicationBuilder) for communication and it is an open protocol, so in principle it would be possible to create your own communication software from scratch. However this needs quite deep knowledge of programming and definitely not easy way to go. It also needs a RAP Communication software option in the robot controller.-Oskuosku2011-07-15 07:30:060
thanks for you answer.I appreciate.Julien0
- 365 IRC5
- 84 OmniCore
