PC SDK problem with VB.NET
Quintrix
I'am taking my first steps in using PC SDK with VB.NET.
While reading the application manual, I came on page 53, and started to create my first SDK application in VB.
First I added my references, then did make my form as discribed, and then I added the code on page 54, 55.
Normally with this, you have the ability to scan the network for controlers.
But that's not working. So I started Robotstudio with an application, to find out if he can scan e virtual controler, but that also is not working.
Is there something missing in the code of the example in the manual, or what's wrong?
SDK must work, because when in work in robotstudio, clicking online, add a controler and give the ip adres, he makes connection with the controler.
On the controler, the option 616-1 is instaled.
Connection with a virtual controller in Robotstudio is working now. However, connection with a controller on the field is not working.
I have turned off the firewall of windows, but this is making no difference.
Anybody can help me?
App.config file was needed if connection was outside local network.
Now it's working fine.
Thanks anyway !
- 336 IRC5
- 67 OmniCore
- 830 RAPID Programming
- 13 AppStudio
