How to upgrade RS 5.13 to 5.14 ?
I have a question. Is it possible to upgrade 5.13 RobotStudio to 5.14 and keeps all projects, stations, systems and libraries ?
If not then maybe there is some easy way to export - import all that stuff to new RobotStudio ? i just dont want to start everything from the begining....
yes, It should not be a problem, make sure to have RS 5.14.01 and 5.14.01 SP1 for a smooth upgrade. A tip is that 5.13 and 5.14 may exist in parrallell on the same computer. (As long as you have valid licenses). If you got any problem with a station after upgrading, don't hesitate to contact us again.0
- 361 IRC5
- 78 OmniCore
- 853 RAPID Programming
- 30 AppStudio
