FlexPendant SDK 5.13 - Accessing the Joystick
I'm developing a FlexPendant application using the 5.13 SDK. Currently I'm using the touch for all input but often it would be more intuitive to use the joystick instead. Is it possible to access the joystick using the SDK?
Regards
John Wiberg2011-06-30 15:16:20
Regards
i have the same question with you.Waiting for ....
