Seting up multitasking in RPID programs
ittoop
Dear sir,
I would like to the procedure to setup multitasking RAPID routines in
my IRC5 robot. For my application I require three RAPID tasks to run in parallel.
One task will take care of user inputs. second task will monitor some
interlocks. third one will monitor and display pressure of some chamber on
the flex-pendent.
Thanks and regards
Ittoop
Hi Ittoop,to add a task ...You go to Configuartion-controller -taskright click to popup option and select add new task. Tasks have three modes. Normal, static and semi -static.Robot task can only be normal (stops on e-stop)Static and semistatic (the program runs in the backgorund). In semi-static mode on power up the PP starts at top.Best to put mechanical units on Normal Task. HIT: you should put debug all tasks in normal before you change them to the perament modes. Robot studio does not let you edit code in static and semistatic mode.0
Hi robot_at_apex,
Thanks for your nice replay. I will try as you have explained. And let you know.
Regards
Ittoop
i search how a semi-static can check if the normal task rob_1 is in manuel, fault or running
can you help for this feature or function in rapid...
thank
You can create a virtual I/O board and map System Outputs to the board. You can then monitor the system outputs in you semi-static task using the DOutput function.BR0 -
ok,, i already use that,
but is wierd, no function to inspect state of other task,
mapping io real or virtual and use process of controler for this type information,,, is waste power,, no?
thank's
Yanick2011-08-15 23:30:230 -
Hy!
I try to add new task, but this button is inactive. Can anybody help me?
Thx
do you have buying the option?
No! I have a free 30days trial version. Maybe, that is the problem?
Hi,I think what Yanick was asking was have you taken the Multitasking option when setting up your virtual controller?RegardsGraeme0
Here is what worked for me. First of all, you need a controller with the Multitasking option enabled. To do this
- Create a new RobotStudio station with Robot Controller -> Choose your robot
- (Controller menu) -> right-click on the current station’s controller -> Shutdown
- (Controller menu) -> System Builder-> select the controller -> Modify...Next->Next->Next->Next-> Add the following options
Now you have a controller configured correctly. To add a new task- (Controller menu) -> configuration editor -> controller -> Task -> New Task…
Task in foreground: select the first taskTrustLevel: NoSafetyIt is important to have the type set to SEMISTATIC since this is what allows the task to run in the background. Now you can run multitasking. If you happen to have to modify the background task, it will be impossible to do this directly on the real controller since the task will run indefinitely on the background, even in case of emergency stop. To modify the task- Change the type of the secondary task to NORMAL
- Do a restart (warmstart)
- Modify the code
- Put the task back to SEMISTATIC
- Restart the controller
Regards,0 - Create a new RobotStudio station with Robot Controller -> Choose your robot
