Quaternion diff operation "q1 == q2 +- tol"
Laro88
Hello.
Is there any way in RAPID to compare quaternions and get an absolute value that means something like :
"Angle in radians between q1 and q2"
I need to test if a the current position is equal a specific position in RAPID, testing both xyz and orientation. Basically I need to make the program test if the position and orientation is so close that it in real life does not matter if I ignore the position and orientation mismatch.
Best Regards
Jes
Best Regards
Jes
HelloThere is a RAPID function called: EulerZYX that allows you to get an angle in each direction: X, Y, Z. So you compare the 3 angles from the 2 positions.Best regardsMarcel0
Hi,See this post http://forums.robotstudio.com/forum_posts.asp?TID=5246.The RAPID code is comparing the current postion joint angles with a predifined postions joint angles.Hope this helpsRegardsGraeme0
Thank you, both of you, will test it when I get back to the task...
- 350 IRC5
- 848 RAPID Programming
- 23 AppStudio
