Robot Cell - Robots Greater Then 4
k_singh
How do you set up a station and controller for a cell that has more then 4 robots? Do you have to create (2) controllers? If so, how?
Yes you have to setup two controllers. To add a controller, go the Controller menu and select Add System.
ABB Robotics0
This discussion has been closed.
