Remote Controlling
Townes
Hi all,
I'm new to RobotStudio and I am currently facing some problem..
Does anyone know how am I able to remote control my ABB-120 Robot without using a FlexPendant to run it?(instead using my computer to control the movement of the robot)
Aaron N.
Aaron N.
Hi Aaron,You can not jog the robot from your PC as you do with the joystick on the FlexPendant, but if you take write access to your PC you can start and stop the robot program from the Online tab in RobotStudio.Best regards,
Yes sir Anders is right you can't jog your robot from the pc.i try to find out the solution by which you can do that.cause there are so many different options are available.0
- 364 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
