IRB 460 weight handling
bmrgud
Hello to all, I would need info about maximum weight handling of IRB 460, it is mentioned in technical specifications that it can handle 110 kg. If I use flex gripper of 60kg weight and I palletize 50kg bags, it would be right on limit, do you think it is smart to go with IRB 460 or it's safer to use IRB 660. Thanks in advance for any info or suggestion.
Do not limit yourself in the analysis of the weight. I recommend you to ask your ABB contact for the RobotLoad application with IRB460 data, taking in account load cog and inertia.
- 367 IRC5
- 858 RAPID Programming
