RSSDK - Addin Real-Time Update
IRB120
Is it possible to stream some data with an addin button and then move the robot in the same time?It seems that Robot Studio waits the end of the stream and then move the robot!I've tried to create a thread but robotStudio invoke an exception when creating the path!
Any idea?
John Wiberg2011-10-04 14:07:56
Any idea?
Hi there,I'm guessing that you are experiencing .NET event handling. Look at this MSDN example to see if DoEvents is the solution to your problem.
John
Developer Center0
