SM Enhancement: ProjectApplicationVariables Editor
I have some opinions about Project Application Variables window in ScreenMaker that can be enhanced.
* Skip the rename button and make "Name" column editable instead as the Value column is.
* The dropdown in column "Type" needs several clicks to open.
* The dropdown in column "Type" is not sorted by name.
  • Hello Daniel,
    Thank you very much for this valuable feedback. We will bring this up for discussion.
    Thanks again!
    Anders Jahnberg
    ABB Robotics
