SM Bug: SM-Doctor fault diagnosis
Tedenljung
in UpFeed
When I run SM-Doctor it say that I have Unused events.
This is wrong diagnose, the events are used but they are called from other actions.
Tedenljung2011-10-06 16:19:58
Hello Daniel,Thank you very much for this valuable feedback. We will add this to the list and bring it up for discussion.Thanks again!Best regards,
Anders Jahnberg
I have now created a small example to explain what the issue is about.Load this project and hit SM-Doctor, it will tell you there is an "Unused Event".But the event is in use in the project!0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
