FP SDK - NumPad
axel
Hi!
John Wiberg2011-10-04 14:08:29
I'm trying to implement a numpad in a flexpendant application, but since I'm quite new to<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
this I wonder how to implement it? The manual just mention something about connecting the pad to a textbox?
BR
B Axel
I gave up and used a CompactAlphaPad instead, but still I'm curious how to use the NumPad.// Axel0
Someone know how to use it ?I can't see the numpad on my form !![VS2008 + FlexPendant]0
Got the same problem, can't see the NumPad on the form.
In an older version i used two years ago(I think RAB 5.11) it works ...
Anyone info's about that?
Got the same problem..
How to use NumPad control??? there are too few documentation about it in the FP SDK (v5.14).
It's can be used only with TextBox target??
I have used the NumPad function till v5.13 and it worked in the following way:Declaration of the NumPad - in my case NumPad_Joints and then I connectedthe target of a TexBox (see last command) with the NumPadthis.numPad_Joints = new ABB.Robotics.Tps.Windows.Forms.NumPad();
this.numPad_Joints.BackColor = System.Drawing.Color.White;
this.numPad_Joints.EnablePoint = true;
this.numPad_Joints.EnableSign = true;
this.numPad_Joints.ExponentFormatButton = false;
this.numPad_Joints.Location = new System.Drawing.Point(331, 29);
this.numPad_Joints.PointText = ".";
this.numPad_Joints.Size = new System.Drawing.Size(191, 191);
this.numPad_Joints.TabIndex = 33;
this.numPad_Joints.Visible = true;
numPad_Joints.Show();
numPad_Joints.BringToFront();
this.numPad_Joints.Target = this.tb_NumPad;
Maybe it helps you.
BR/
Chaos0 -
Tnx Chaos about your help!!
but I have another question: How I can do it as screenshot?? (is "Program Data" edit num value).
If the numpad target can be only a texbox, how we can do it about listView specific cell??? maybe is a textbox overlay value cell while numpad control is shown?? some ideas???
bye Ema!
- 304 PowerPacs
- 354 IRC5
- 850 RAPID Programming
- 26 AppStudio
