Setting Program Pointer
IRB120
Hello ,
when i move the virtual robot to a specific target(sent by an addin button) and then i add another target(from another addin button) to the same path the robot doesn't move to the second target because it says "Program Pointer Lost"!How can i set the pointer from the addin ?
hi??Oi have the same question with you,do you solve the problem?if you have solved,please tell me how to solve it.Looking forward your replying!Thanks a lot0
- 365 IRC5
- 84 OmniCore
