Autopath
TomR
When using autopath, is there any way I can make it automatically default to curve selection and retain the max chord deviation that I set (1 mm)?
I want to create a large number of individual paths from curves and it is quite time consuming having to click on curve selection and re-set the max chord deviation each time.
There is no way to automatically do this, unless you not write an Add-In to do it.Best regards,
ABB Robotics0
