FP SDK ListView ItemCheck
Hello
I am developing a FP app, using a listview control with Checkedboxes (I'd like to use the ABB control because of its layout).
I need to intercept the event that occurs when the state of a checkbox changes, just like ListView.ItemCheck Event
in for the standard windows form control.
I can't find this event..doesn't it exist in the ABB control?or anything similar? (the same question as for CheckedItems Property of listview)
Thanks in advance
BR
  • Micky
    Micky ✭✭✭
    Hello Gomez,
    there is no direct event to detect if a checkbox has been changed, but you  you could use the event "ItemActivate" to do this.
    Via the property "SelectedItem" or "SelectedIndex" of the listview it is possible to get access to the activated listview item.
    Example:
    private
    void listView1_ItemActivate(object sender, EventArgs e){
    if (listView1.SelectedItem != null){
    ABB.Robotics.Diagnostics.
    Trace.WriteLine("Item activate " +    listView1.SelectedItem.Text + ": " + listView1.SelectedItem.Checked.ToString());
    Best regards
    Micky
  • Thanks for responding
    This was the solution I also was thinking to use, but I wanted to be sure that there is nothing already implemented as for collections of selected items and their events. Ok, I'll do it manually..
    Thanks again
    BR
