RS Feature: Direct Help using F1
                    Tedenljung
                                  in UpFeed
                    In RapidEditor it would be a good thing to be able to select a command/function and press F1 to bring up the Rapidmanual and go to right page.
            Hello Daniel,Thank you very much for this valuable feedback. We will bring this up for discussion.Thanks again!Best regards,
 Anders Jahnberg
 ABB Robotics0
            That would really be a nice feature.How should it handle user defined functions?John
 Developer Center0
            Well, that is a good point...But I guess that a message telling that this is not a ABB function and help is not available is a good start.But if an Integrator has a own library with functions they can write a manual for it and RS will use it the same way, but I do not know how?Also there is different PowerPacks that can have special functions with help.0
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 31 AppStudio
