How to save [ArcWelding PowerPac]
Hi Leonard....
Do you mean that,
you have a ready program & wants to download it to the real working controller?????
Vishal,
vishalpatil3.82@gmail.com OR
vishal.patil@electronicagroup.com0 -
Yes0
Hi LeonardYou can do that thru the Virtual FlexPendantJust go to Program Editor window. Choose proper task where your module is.Click Modules tab in the top and when you see the list of all modulesjust click the one you want to save and in the bottom click File -> Save module asSave it on a USB stick and load at the real controller pretty much sameprocess as saving just at the end choose Load module instead.Cheers!0
Thank you.0
the robotics flat runtime and development accoutrement do not appear with any automatic hardware. We fabricated abiding our casework plan with a array of consumer, hobbyist and top end robots but you accept to buy the accouterments seperately. Alot of these robots are accessible in Europe (most of them in fact appear from europe) and they are priced reasonably. Plus, if you accept no apprentice hardware, you can consistently body absolutely nice robots in our simulator.
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
