How to use transparent texture
Thomas J
How do you create panels with a testure that is transparent like on the SC_FencePanelCreator?
We are trying ot use this new feature with no luck.... It is not see through!
Is there a tutorial available or any instruction? The RobotStudio Help file lacks information on this.
Looking forward to your reply...
Thomas H. Johnston
PACs Application Engineer
You need to create an image with an "alpha channel" which define the colour who should be transparent. To create an image with an "alphas channel" you can for example use the software "GIMP" (www.gimp.org) which is free to use.Best regards,
ABB Robotics0
