Graphics Card requirement for RS
What is the Grapics card size requirement in RS in Windows7 64bit edition.
i want to work with huge assemblies(after doing Remove geometry).Size of the station will be 250MB. i want this to make a 3d layout of the complete Line. there will be 39 robots and its tools. i'm getting error out of video memory and RS gets closed. My RAM size is 8GB.
Regards,
JJ
Hi,Probably are you running out of ram memory. RobotStudio can use up to 4GB RAM. And if that is the case, the only solution is to make the station smaller.Regarding graphics card can you read this in release notes:
High-performance DirectX 9 or OpenGL-compatible graphics card with the corresponding up-to-date drivers installedBest regards,
Here is the error which i was getting.0
The error message says that you have run out of RAM memory. So unfortunately is your station to large for RobotStudio to handle.Best regards,
ABB Robotics0
- 365 IRC5
- 84 OmniCore
