TriggL with zones
I have a TriggL instruction with a TriggInt, but the trap routine only runs if I use a fine point. In the rapid reference the example has a zone configured. I've tried setting the TriggInt to fire at various distances from the target position, inlcuding 0, but it only ever works if I use a fine point.
CONNECT OpenClampsInt WITH OpenClampsTrap;
  TRIGGINT OpenClampsTrigg,0,OpenClampsInt;
  !Move up to the flyby and open the clamps once clear of the product
  TriggL pNextPosition,DepartSpeed,OpenClampsTrigg,fine,Gripper;
  IDELETE OpenClampsInt;
Any ideas what I'm doing wrong?
  • Hi
    I think the reason is that when using zone, the IDelete instruction is executed before trap is fired. Try to execute without IDelete or execute it later in the program.
    -Osku
  • Hi
    I always execute a IDelete before I do a CONNECT in that way you always know that the connect will work and don't have to care about that PP is running ahead.
    Per Svensson
    Consat Engineering
  • You should be able to put the IDELETE just before the CONNECT.
    Then you should be able to change the zone to something larger.
    Thomas H. Johnston
    PACs Application Engineer
  • Thanks, so obvious when you say it like that!
  • [QUOTE=Gizmo]
    Thanks, so obvious when you say it like that![/QUOTE]
    lol, ahahahaha
