WebWare SDK - S4VarSubList [WebWare SDK]
Hello -
Has anyone successfully used "S4VariableSubscription" in a VB project?
I am attempting to create an applicaiton where the user must specify the names of rapid variables that are used for an application in an INI file and then use that information to connect to variables in the robot controller automatically.
Can someone provide some working examples of this object?
Thanks,
Tom
PACs Application Engineer
Hello Tom,
Here is a simple application that demonstrates the use of the S4VariableSubscriptionList object.
The user can view the current var sub list for an alias and also add their own vars to that alias profile.
Please note that this application is for demonstration only, and is not intended to represent "production" code.
Russell Drown0 -
Hello Russ -
Thankyou very much for your example, it was most helpfull.
After playing for a while and trying different things, I was finally able to do what I needed simply by using the S4VariableSubscriptionList wrapper only. (It worked virtually anyways, I will know later this month if it works on the real robot)
Set S4VarSubLst = Helper1.VariableEventList
S4VarSubLst.RemoveAll
S4VarSubLst.Add mstrEnable, "bool", 0
S4VarSubLst.Add mstrPurge, "bool", 0
S4VarSubLst.Add mstrPurgeTime, "num", 0
S4VarSubLst.Add mstrDwell, "num", 0Then using the num and bool changed events in my program I was able to accomplish what was needed.
Something must have gotten messed up in my previous attempts because I could not "delete" a variable subscription until I re-boot my computer. After re-booting everything worked as expected in the property pages and the VB code page.
Thanks again for your help.
As always it is much appreciated.
Tom
Thomas J37991,6144097222Thomas H. Johnston
PACs Application Engineer0
- 303 PowerPacs
- 353 IRC5
- 850 RAPID Programming
- 25 AppStudio
