Virtual Controller failed
After updating IE7 to IE8 and installling Mcafee as a service I can not open a station in RW5.14.02. The message is:
"There was a problem when initializing the Virtual Controller.
RobVCFactory.Launch failed,hr=c0040701
The release directory C:PROGRAM FILESABB INDUSTRIAL ITROBOTICS ITMEDIAPOOLRobotWare_5.14.0204
is missing or corrupt,and cannot be used when launching a VC.
Select Retry to start the system again or Cancel to remove the system."
I check the directory and it is OK, in fact I can not open any station with different robotware versions.
Firewire is disabled.
I try to repair the installation but the problem is not fixed.
Any ideas.
Javier Garcia
If you have verified the path and it worked fine before the software update, I'm pretty sure that McAffe is where to focus... Make sure that all RS processes are marked as exceptions in McAffe.Best regards,
Anders Jahnberg
ABB Robotics0
