IRBP 250R needed (only 300R present is RS)
SjoLi
Is there any why I can import an IRBP250R into RS5.14.02?
At the moment I'm forced to use the IRBP300R which is slightly different.
RobWelding
The Netherlands
The Netherlands
I found out that it is present in the ABB library but not mentioned in the menu's. So I had to find it via the explorer.RobWelding
The Netherlands0
