Mechanism Modeller
riva_tnt
Why I can't compile mechanisme that I have create eventhough all the component is OK? Anybody can help me? Thanks
Din
Hi,If you have to low resolution on your PC the compile button will not be visible. Try to undock the "Create Mechanism" window and dock it to the right side of the output window.
Dear Anders,Problem solved.ThanksDin0
