Working Offline and Online
mechman
What is the correct method of bring a system from offline to online? It seems like there should be some kind of synchronize option.
In the past I have been manually copying all data in each module to the online system.
Hi,The normal method is to save the moudules (or all program modules as a program) in the Offline-tab, then load them into the online system from the Online-tab.Best regards,
That worked, thank you.
