Working Offline and Online
What is the correct method of bring a system from offline to online?  It seems like there should be some kind of synchronize option.
In the past I have been manually copying all data in each module to the online system.
  • Hi,
    The normal method is to save the moudules (or all program modules as a program) in the  Offline-tab, then load them into the online system from the Online-tab.
    ABB Robotics
  • That worked, thank you.
